1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Burt and km under Solaris
To: [email protected]
Date: Tue, 20 Feb 1996 11:44:10 GMT
BURT
burtrb now works correctly.
I had a minimal environment to run my EPICS applications ... which missed to
define the cc compiler. As John Winans suggested, I put the SUNWspro cc compiler
in my path and now everything is ok.
I tried also this :
> If you are not using any macros (ya know #defines) in your BURT files, you
> could probably make a shell file named 'cc' in your path when running BURT
> that simply contains "cat -;exit 0".
I  had the following result :
--- Start processing files
file >/home/sigx0/sig/ttf/burt/injector/inj1.req<
preprocessing ... done
ERROR: BurtProcessRequestFile() encountered invalid pvar name in line ><
**** END BURT LOGFILE
Anyway, my problem is solved as we have access to the right c compiler.
I have always the message
"did not find any read only notify values ... NO OUTPUT FILE CREATED"
in the burtwb logfile but the restore is ok.
KM
I tried to transfer km.gz from ftp.aps.anl.gov several times monday and this
morning without any success. I had a terrific 50 bytes/second transfer rate and
my ftp tool seems to be cute enough to cut the transfer after 15 minutes seeing
that the task is impossible !!!
Any suggestions to boost the link ?
Many thanks for the help
	Jean-Francois Gournay
	CEA Saclay
Prev: Re: macro substitution William Lupton
Next: description for archive record Matthias Clausen DESY -MKV2/KRYK-
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Burt and km under Solaris John R. Winans
Next: Field type Andy Kozubal
