1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Burt and km under Solaris
To: [email protected]
Date: Fri, 16 Feb 1996 18:01:48 GMT
BURT
	I am trying Solaris versions of burtrb and burtwb (many thanks
to Andrew Johnson, by the way).
	I am using exactly the same files that I used under SunOS.
	I have now the following diagnostics :
**** READ BURT LOGFILE
--- Start processing files
file >/home/sigx0/sig/ttf/burt/injector/inj1.req<
preprocessing ... ERROR: BurtPreprocessFile() cc abended exit_status 1 signal
-1ERROR: process_command_line_args() could not preprocess non-SDDS file
when I try a backup
and :
STEERER_H0INJ1_ONbo ... ca_array_put() nelem 1 ... OK
STEERER_H1INJ1_ONbo ... ca_array_put() nelem 1 ... OK
STEERER_H2INJ1_ONbo ... ca_array_put() nelem 1 ... OK
STEERER_H3INJ1_ONbo ... ca_array_put() nelem 1 ... OK
flushing with ca_flush_io() ... OK
--- End writes
did not find any read only notify values ... NO OUTPUT FILE CREATED
when I try a restore.
	Another point : burtrb and burtwb needs to link libXt.so.5.0  and
libX11.so.5.0 at startup. Why ? Moreover, Solaris 2.5 is delivered with
libXt.so.4.0  and libX11.so.4.0 .
KM
My Sundials are not seen by the Solaris version of km, although some other
programs run fine with them.
They are connected to tty/a and the configuration is done with bdconfig.
	Thanks in advance
	JF Gournay
	CEA Sacaly
Prev: km under Solaris Fred Vong
Next: Re: Burt and km under Solaris John R. Winans
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
