1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: PACT -> SDIS
To: [email protected], [email protected]
Cc: [email protected]
Date: Wed, 14 Feb 1996 11:56:57 -0600
re...
> When I refered to a dillema I was only referring to what to do about
> monitoring the PACT field.
Since the time scale is seconds, you could get a pretty good look at
that PACT field by attaching the input link of, say, a BI record
scanned at 10 Hz, and monitoring the BI's VAL field.
If you needed better time resolution, you could make an infinite loop:  A
WAIT record's output link (OUTN) triggers the (now passive) BI record,
whose FLNK triggers the WAIT record again.  You can set the WAIT's
output delay (ODLY) in .017 sec increments.  (If you set it to zero you
can run at kHz speeds, but you'll have to use dbpf at the VxWorks
prompt to break the loop, since you'll not be able to get a caPut in
edgewise once the loop is made :).
Tim Mooney
Prev: Re: PACT -> SDIS Marty Kraimer
Next: OPTOMUX ROLF KEITEL, TRIUMF, VANCOUVER, B.C.
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: macro substitution (forwarded from Marty) William Lupton
