1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: macro substitution
To: [email protected]
Date: Tue, 13 Feb 1996 14:53:22 -0600
More about macro substitution:
Nicks writes:
>FROM [email protected] Mon Feb 12 14:02 CST 1996
>1. I don't think the current syntax precludes the ommission of a
>   reserved word such as `set' or `define' - just an embedded equals sign
>   may be sufficient. Then the amount you type must be about the same.
>2. I believe the current dbLoadTemplate is really just a host side tool
>   since it writes to stdout. Am I correct? Thus you don't really have to
>   worry about the number of file opens if you are just wanting to provide
>   the same functionality. Basically, I thought the conclusion was that if
>   you have many files and use ftp you would always use dbAsciiExpand on
>   the host for efficiency reasons.
I disagree, dbLoadTemplate() is useful running on the IOC.
>3. dbLoadAscii could always buffer its file handles... (No, I don't think
>   I like this either - it isn't really realistic if you are using ftp on
>   VxWorks).
This seems very bad.
>4. I agree to supporting both formats. However, I think the syntax that is
>   chosen should be consistent, and the semantics such that:
>file gizmo_database.db
> i1{ pre=part1,parm=big,   alarm_limit=20 }
> i2{ pre=part2,parm=medium,alarm_limit=30 }
>is identical to (changing my syntax to match yours):
>pre=part1
>parm=big
>alarm_limit=20
>include "gizmo_database.db"
>pre=part2
>parm=medium
>alarm_limit=30
>i.e. the `file' statement is sort of an implied for loop.
> Now the user needs to maintain 300 files.  Tell me if there is something
> I am misunderstanding.
>No, I think you had it absolutely right.
I do not like this at all.  Remember, we have many users already set up
to use the other format.  I think it is unreasonable to ask them to
change to a format that increases the maintainence of their files and
possibly reduces readability of substitution variables.
Jim
Prev: Re: PACT -> SDIS Marty Kraimer
Next: Re: PACT -> SDIS Ian Smith
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: macro substitution William Lupton
Next: Re: macro substitution William Lupton
