1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Allen Bradley Driver
To: [email protected]
Date: Tue, 13 Feb 1996 12:53:35 -0600
The Allen Bradley Driver (abDrv) in EPICS 3.12.2 and earlier may
fail doing btReads and btWrites with new versions of the 6008-SV2R
scanner. This does NOT impact ordinary bi, bi, ai, ao support.
It will only cause a problem if you have written special support
that issues btRead or btWrite commands to abDrv. I found
the problem when I started using the new scanner with special DCM
support I wrote.
Below is a complete list of changes that will be available in the new
version of abDrv. If anyone needs the new version imediately contact me.
The one-line documentation has already been changed.
Marty Kraimer
	Analog Output Block Transfers were being requested too frequently
	If link_status command fails (3 times in succession) adapters
	are now immediatly declared down.
	For btRead and btWrite, The driver now enforces a timeout of 5 seconds
	which is 1 second more than scanner itself enforces. This is so that
	if scanner throws away a BT request it will still timeout.
	For btRead and btWrite is is no longer permissible to issue a
	new btRead or btWrite from tha callback routine.
	The on line doc has the following two changes:
	abConfigBaud has arguments (link,number) (Old doc was wrong)
	Now states that new btRead/btWrite can NOT be ussued from callback.
Prev: Re: macro substitution William Lupton
Next: Re: PACT -> SDIS Marty Kraimer
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: macro substitution (forwarded from Marty) William Lupton
Next: OPTOMUX ROLF KEITEL, TRIUMF, VANCOUVER, B.C.
