g+
g+ Communities
Argonne National Laboratory
1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Subject: Displaying waveforms
To: tech-talk@aps.anl.gov
Date: Fri, 26 Jan 96 01:51:27 PST
Hi guys:
If you have the time could you answer a question?
Why would the following code fragment not work?
double waveform_array[16384];
assign waveform_array to "WAVEFORM_ARRAY.VAL";
/****** Acquire data and stuff it into an array: this part  *****/
/****** works because I can print out believable data using *****/
/****** the printf statement below.                         *****/
/* write to waveform */
%%	array1_ptr=lpanarray1;
%%	for(count=0;count<lnumsamples;count++)
%%		waveform_array[count] = (double)(array1_ptr[count]*3.091e-10);
%%		printf("%e\n",waveform_array[count]);
	pvPut(waveform_array);
My database file for this record looks like this:
    record(waveform, "WAVEFORM_ARRAY")
        field(DESC, "Array for HP positions")
        field(SCAN, "Passive")
        field(PINI, "NO")
        field(PHAS, "0")
        field(EVNT, "0")
        field(DTYP, "Soft Channel")
        field(DISV, "1")
        field(SDIS, "0")
        field(DISS, "NO_ALARM")
        field(PRIO, "LOW")
        field(FLNK, "0")
        field(RARM, "0")
        field(PREC, "4")
        field(INP, "0")
        field(EGU, "nm")
        field(HOPR, "1.0e-08")
        field(LOPR, "-1.0e-08")
        field(NELM, "16384")
        field(FTVL, "DOUBLE")
        field(SIOL, "0")
        field(SIML, "0")
        field(SIMS, "NO_ALARM")
Instead of putting this array into my waveform record, the dang computer
prints the error message:
error from CA on WAVEFORM_ARRAY.VAL
The array or data structure specified will not fit in CA message buffer
Any ideas what's wrong? Thank you very much!
John Spring
Prev: Re: request to modify db_name_to_addr for USHORT mapping Marty Kraimer
Next: EPICS Master Tree Developers Marty Kraimer
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Next: Re: Displaying waveforms Marty Kraimer
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
