g+
g+ Communities
Argonne National Laboratory
1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Subject: ATTN Base Developers - base/include
To: tech-talk@aps.anl.gov
Date: Fri, 19 Jan 1996 09:42:46 -0600
The following changes will be made to the base directory structure:
1) All files in base/include will be moved to directorys under base/src.
   During build public .h files will be installed into base/include
2) base/rec will disappear. The generated h files will be installed in
   base/include and the database definition files (.db) into base/db
The base/include should NOT contain CVS controlled files.
These files should reside in a base/src/xxx directory and installed
into base/include. In addition the header files for menu and record
definitions should also be installed in base/include. The ascii
database definition files (.db) should be installed into base/db.
Unless someone expresses strong opposition Janet and I will do the following
next Monday:
1) Create a new directory base/src/include
2) Copy all files currently in base/include to base/src/include
3) Perform a "cvs rm" on all the .h files in base/include
4) Make an initial stab at moving as many files as possible from
   base/src/include to the base/src/xxx directories where they belong.
5) Perform a cvs add on each include file that was moved.
6) Make everything build and install all necessary .h files into base/include
When we are done only a few files should remain in base/src/include. We can
decide later what to do about them.
If any base developer has made modifications to files in base/include
in the master EPICS tree at APS you may want to perform a cvs commit.
Before making the changes listed above we will perform a cvs update
on everything in base and config.
Marty Kraimer
Prev: Re: Doc: Link Field Syntax Marty Kraimer
Next: symbols for scan, dfanout, and seq records Sarah Quady
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
