1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Ascii databases
To: [email protected]
Date: Wed, 17 Jan 1996 08:35:57 -0600
Nick Rees suggested that the path for the ascii database files should
be just like the UNIX path, i.e. a list of colon separated directories.
After thinking about it, I agree completely. I dont know what I was
thinking. Here is the way path will be handled:
NEW METHOD FOR PATH
The path will follow the normal Unix conventions, i.e. it will be of
the form:
directory:directory: ... :directory
The static database access library will provide the following
routines
dbPath(pdbbase,"<path")
dbAddPath(pdbbase,"<path>")
The following commands can be given in definition files
path "path"
addpath "path"
dbExpandInclude will have the format
dbExpandInclude -I "path" file1 ...
The ioc routine dbLoadDatabase will have the format:
dbLoadDatabase("file.db","path")
dbExpandInclude and dbLoadDatabase determine the default path as follows:
  If the path argument is not NULL it is the default
  else if the env variable EPICS_DB_INCLUDE_PATH is defined it is used
  else the default path is ".", i.e. the current directory.
END MESSAGE FOR PATH
Note also that, per Jeff Hills suggestion, all references to ascii are being
removed. I hope to have a new beta release and greatly revised Application
Developer's Guide ready in about 2 weeks.
Marty Kraimer
Prev: default drvSup.ascii Jeff Hill
Next: Re: CA internal failure Jeff Hill
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Ascii databases Nick Rees
Next: Returned mail: Cannot send message for 1 hour Marty Kraimer
