1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Bug with initDatabase()
Date: Wed, 12 Jul 1995 09:24:29 -0500
> From denali!greene Tue Jul 11 15:42 CDT 1995
> From: <greene%[email protected]>
> Subject: Bug with initDatabase()
> To: <[email protected]>
> Date: Tue, 11 Jul 1995 14:40:32 -0600 (MDT)
> X-Mailer: ELM [version 2.4 PL24]
> Mime-Version: 1.0
> Content-Transfer-Encoding: 7bit
> Content-Type> : > text/plain> ; > charset=US-ASCII>
> Content-Length: 1194
> I've encountered a bug while porting EPICS to the Hytec CAMAC controller.
> The problem is in initDatabase() which is called by iocInit().  The
> interesting part is how this function ever worked.
> The problem is in the first call to ellFirst().  If there are no
> records defined for a specific type, then the field precLoc->preclist
> is null.  However, the call to ellFirst() does not check for this
> condition and will return a garbage pointer.  This works fine with
> the NI VXI cpu030 card because the data at 0x0 is also 0x0 which causes
> the for-loop to continue with the next record type.  However, with
> the Hytec card, 0x0 is the start of EPROM which contains non-zero
> data.
> Obviously I can easily fix this by checking for a null preclist value
> but I'm curious how this works on other controllers.  I'm also concerned
> with other areas in the EPICS code which might pass a null ELLLIST value
> to ellFirst().
I just looked at the code. A few ststements above the call to ellFirst is
the statement
    if(!precLoc->preclist) continue
Thus if no records exist the call to ellFirst will never be made.
Marty Kraimer
Prev: Bug in initDatabase() Patavalis Nikos
Next: Re: Bug with initDatabase() greene%denali.UUCP
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Bug with initDatabase() greene%denali.UUCP
