FYI, here's the reply from Heurikon.
> From [email protected] Thu Dec 7 11:11:16 1995
> From: "David Greene" <[email protected]>
> Date: Thu, 7 Dec 1995 13:10:25 -0600
> In-Reply-To: [email protected] (Bill Brown)
> "Re: (Fwd) Re: VxWorks Tapes" (Dec 5, 12:30pm)
> Bill,
> Following is a suggested workaround, but first is a general suggestion.
> IN GENERAL:
> Normally, for a specific target, it is best to define options in the config.h
> file. The settings in this configuration header file supercede anything set in
> configAll.h. The "Programmer's Guide: VxWorks 5.2" explains this very well in
> sections 10.3.1.1 and 10.3.1.2 (and mercifiully with less than a page of text).
> WORKAROUND:
> Here is the workaround I suggested to the other customer who is seeing
> apparently the same problem:
> -Put all desired option definitions into config.h instead of
> configAll.h
> -INCLUDE_SECURITY may cause compile problems when defined in config.h,
> so I put it in configAll.h
> This made the problem go away. I don't yet know why and am still investigating
> the root cause.
> Dave
It works, altho I haven't a clue as to why. One can go on for days about the
wisdom of invoking which things in what .h files. I thought that our setup
was a fairly generic release from WRS, but since I didn't originally build
it (or install the release) I could be wrong.
In anycase, if anyone else wants to use these boards, it would be a good
idea to squirel this info away in a "safe place.
I'm impressed with the support I got from Heurikon on this.
-bill
Re: GDCT/freeGDCT under solaris 415
Re: A C++ API for the pcas 415
<1995>
Re: building vxWorks for nitro-260 John R. Winans
A possible alignment fix side-effect. Peregrine McGehee
<1995>
