1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: passing arrays via input links
To: [email protected]
Cc: [email protected]
Date: Wed, 6 Dec 95 14:46:00 HST
Hello All,
I've created a couple of specialized processing records that need
to pass arrays from one record to the next via input links.
I've struggled with it but could not find a way to get full array
from the output of one record to the input link of the next.  At
most I get the first element of the array only.
For now I've worked around it, by passing the array pointer (via
and input link) and assigning that to another array ptr in the receiver,
hence they both reference the same memory locations.
I don't particularly like this implementation because if the receiver
updates the data on his side, its also reflected on the other end.
Can anyone shed some light on passing arrays via input links?
Thank You.
Kevin Tsubota
c/o W. M. Keck            ph: (808)885-7887
P.O. Box 220
Kamuela, HI 96743
Prev: Stepper Motor Drivers Brian Leckie
Next: Re: passing arrays via input links Marty Kraimer
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
