Peregrine,
> Note: the _seqAuxTask runs at one priority level above the actual
> sequencer app - and it's _only_ function is to call
> ca_pend_event(10.0) forever. Why is that?
When we were not using select() in the client lib under vxWorks there was one task
in recv() for each file descritor. Since recv() does not have a timeout
then there was the possibility that none of these tasks would unblock
and periodically take care of CA background activities (such as
locating channels and detecting disconnects). Therefore it was
necessary to periodically call ca_pend_event() under vxWorks (similar
to what is required under single-threaded os). Now that we have an independent
task under vxWorks which is taking care of all of the file descriptors
and periodic background labor via select() there is no longer a requirement
to periodically call ca_pend_event() from client side applications
that are running under vxWorks.
Jeff
______________________________________________________________________
Jeffrey O. Hill Internet [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos, NM 87545 USA FAX 505 665 5107
Re: A possible alignment fix side-effect. Andy Kozubal
Stepper Motor Drivers Brian Leckie
<1995>
<1995>
