1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: R3.12.2 vxworks config
To: [email protected]
Date: Tue, 14 Nov 1995 22:53:20 -0600
>The files located within the config/mv167 directory seem to be modified from
>the WRS 5.1 release, not the 5.2 release.  The config/all files are modified
>from the 5.2 release.
I can't remember all the details of the 5.2 install at APS... I remember that
the CD from WRS was a nightmare and that installing from it screwed up
ownerships, permissions and the sim-link paths on all the GNU tools.  It is
POSSIBLE that the BSP install was messed up somehow as well.  However, I
am pretty sure I did it myself and I am pretty anal about those things.
I can not see the references to the config stuff in the 3.12.2 release that you
mention.  I suspect they are probably some notes I scrawled out 6 months
ago.  With any luck that config tree is in error.  Just to make sure, could
you tar up and send me/drop off an official distribution config tree of 5.2?
This way I can see if it matches the one I used for 5.2.
NOTE:  If I messed this up somehow, there is probably not going to be any
time for ME to go thru the merge of all that stuff and test it again in 1995.
--John Winans
Prev: R3.12.2 vxworks config Bret Goodrich
Next: Re: R3.12.2 vxworks config Jeff Hill
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
