1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: AR in server mode and cmdClient
To: [email protected]
Cc: [email protected]
Date: Wed, 8 Nov 95 15:28:52 MST
> From [email protected] Wed Nov  8 13:31:50 1995
> Return-Path: <[email protected]>
> Date: Wed, 8 Nov 95 10:29:45 HST
> Content-Length: 881
> X-Lines: 24
> Dear all,
> Peregrine wrote:
> > cmdClient is in base at $EPICS/base/src/util/cmdClient.c and the
> > executable should be in $EPICS/base/bin/<arch>.
> Deb Wrote:
> > Perry indicated where to find it.  My version of 3.12 indicates that
> > base/src/util/cmdClient.c was put in the cvs Attic at some point.
> > If you can't find it in your release of EPICS, it's probably retrievable
> > there somewhere.  I'm not sure if we should get it set up in extensions/ar
> > or what.
> I assume that most of the stuff from base/src/util was moved to
> extensions/ar/syd? Apparently cmdClient.c was omitted?
> Anyway, as a stopgap, I have moved cmdClient.c (I had it in the Attic
> from Beta1) there too and butchered the Makefile to build it (it
> introduces a cross-dependence between ar/syd and ar/ar which needs
> fixing since cmdClient needs ezsSockSubr which is in ar/ar...).
> Thanks for your help,
> William
Hi William,
When I moved arr (the tck/tk archiver retriever) into EPICS for solaris,
I ran into a similar problem needing routines that used to be in
libCom for 3.11 but were restricted to ar in 3.12.
I created a library called arAccessLib that had all of those components
of ar which used to be in libCom and are not in syd.  Janet has put
it in the newer 3.12.xx Makefiles for extensions/src/ar/ar. The library gets
installed in extensions/lib.  When your AR_cmd gets integrated back with
epics, you should be able to obtain ezsSockSubr from that library.
Rozelle
Prev: Re: AR in server mode and cmdClient Jeff Hill
Next: iocInit hangs connecting to the log server Jeff Hill
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
