1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: ezcaIDL vs CaIDL
To: [email protected], [email protected], [email protected]
Date: Tue, 7 Nov 1995 17:11:14 -0600
> > I found out that in general that the caget in ezcaIDL is
> > 3 times slower than CaIDL.
> > In case 1 a caget is repeated 100 times on an AI record, in case 2 a
> > caget is repeated 100 times on a waveform record with float type with 4000
> > elements ...
> >                   CaIDL             ezcaIDL
> > Case 1             1 sec             4 sec
> > Case 2             3 sec             9 sec
> This is simply incorrect.  These results were the result of using the ezca
> default timeout of .05 seconds.  The correct comparison is with a very short
> timeout in ezca.  In this case the following results are obtained on a
> Sparc LX.
>                    CaIDL              ezcaIDL
> Case 1             0.72 sec            0.83 sec
> Case 2             3.05 sec            3.16 sec
> Thus, ezcaIDL is at worst 10% slower than CaIDL.
The actual time out I used in yesturday study for CaIDL, and ezcaIDL both
are 0.001 sec.   And the time I reported is the "REALTIME"  used.
Since Mark reported different time, therefore I did exactly the same
calculation as Mark did again today.
The time used on my Sparc 20 are listed below, I use the same 1.e-6 timeout
in both cases.
                    CaIDL                     ezcaIDL
 Case 1             0.41999996 sec            2.161000 sec
 Case 2             2.6480000 sec             4.217000 sec
The actual run for CaIDL and ezcaIDL are atached below, I just can not
believe why the version of ezcaIDL on our system is much slower then what
Marks's Sparc LX.
RUN FROM CAIDL
kao 186: idl
IDL. Version 4.0.1 (sunos sparc).
Copyright 1989-1995, Research Systems, Inc.
All rights reserved.  Unauthorized reproduction prohibited.
Installation number: 2421-1.
Licensed for use by: Advanced Photon Source
Compiling CaWave ...
Compiling CaWidgets ...
CaWave Version 3.1(Lca2.2) (EPICS Version 3.12.1.3)
IDL> capendevent,time=1.e-6
IDL>     t1 = systime(1)
IDL>     for i=1, 100 do s = caget('chademoai1')
    t2 = systime(1)
    print, 'Elapsed time for caget on AI: ', t2-t1
    t1 = systime(1)
    for i=1, 100 do s = caget('chademowfmax7')
    t2 = systime(1)
    print, 'Elapsed time for caget on 4000 element waveform: ', t2-t1
IDL>     t2 = systime(1)
IDL>     print, 'Elapsed time for caget on AI: ', t2-t1
Elapsed time for caget on AI:       0.41999996				           <=======
IDL>     for i=1, 100 do s = caget('chademowfmax7')
IDL>     print, 'Elapsed time for caget on 4000 element waveform: ', t2-t1
Elapsed time for caget on 4000 element waveform:        2.6480000                  <=======
IDL>
RUN FROM EZCAIDL
kao 205: idl
archsun4
/usr/local/epics/extensions/bin/sun4:/usr/local/epics/extensions/bin/sun4:/usr8/rsi/idl_4/lib/hook:/usr8/rsi/idl_4/lib/obsolete:/usr8/rsi/idl_4/lib:/usr8/rsi/idl_4/examples/hdf_ncdf:/usr8/rsi/idl_4/examples/general:/usr8/rsi/idl_4/examples/wexmast
Run ezcaIDL ...
Run ezcaIDLWidgets ...
IDL>     casettimeout, 1.e-6
    t1 = systime(1)
    for i=1, 100 do s = caget('chademoai1', value)
    t2 = systime(1)
    t1 = systime(1)
    for i=1, 100 do s = caget('chademowfmax7', value)
    t2 = systime(1)
IDL>     for i=1, 100 do s = caget('chademoai1', value)
Elapsed time for caget on AI:        2.1610000				        <=========
IDL>     for i=1, 100 do s = caget('chademowfmax7', value)
Elapsed time for caget on 4000 element waveform:        4.2170000	        <=========
IDL>
Prev: Re: ezcaIDL vs CaIDL Mark Rivers
Next: Re: New Subroutine Record Marty Kraimer
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Converting edd displays to edd2 Paul Martin
