On Fri, 27 Oct 1995 12:43:46 +0100 (MET) Gabor Csuka <[email protected]> wrote:
>The CAN bus now successfully connected to Epics (R3.12.1),
>useing CDI V4.0 interface.
For anyone who doesn't want to use the CDI, I wrote an EPICS CANbus driver which is
already in use on UKIRT (and will be used by Gemini). This drives the TIP810 IP
module and has been tested using the Greenspring VIPC310 and VIPC610 carrier boards
but also has software to drive the mv162 (not tested). Device support is provided
for ai, ao, bi, bo, mbbi, mbbo, mbbiDirect and mbboDirect records with full I/O
interrupt and asynchronous record processing. You can even use EPICS to build a
simulator for another CANbus device to respond to RTRs on the bus.
Documentation is in preparation, and should be available shortly.
- Andrew
O o ._ Andrew Johnson, Royal Greenwich Observatory
__\\_ Madingley Road, Cambridge, CB3 0EZ
__|ooooo|__ Tel +44 (0)1223 374823 Fax 374700
~~\_________/~~ WWW http://www.ast.cam.ac.uk/~anj/
- Re: CAN connection Gabor Csuka
Re: Subroutine Records Marty Kraimer
SUBSCRIBE tech-talk Gerhard Grygiel
<1995>
<1995>
