1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: BURT modifications in progress
To: [email protected] (James F. Harrison)
Cc: [email protected]
Date: Tue, 24 Oct 95 18:30:02 -0500
>I would like for burt to handle arrays larger than it can currently handle, say
>~2000 integers.  This would be useful to save and restore the settings of a GPIB
>instrument, like a Tektronix RTD720 or a Tektronix SCD1000 waveform digitizer.
You are not the only one.  Regrettably, this artificial limit has nothing to do
with BURT.  BURT has no internal limits and (hopefully) never will.  The problem
you cite is related to the buffer allocation size that Channel Access uses.
I believe this buffer size issue is one of the canidates for change in CA version 4.
Jeff Hill is the guy you should be talking to about removing the dependancy on the
static buffer size(s).
FYI --
There is supposedly a macro (what a shock!) in the CA header files somewhere that
you can change and rebuild everything to use a larger buffer allocation... if that
suits your needs.  Again Jeff is the guy for the details.  It should not coma as
any suprise that the current buffer size is set to 16K [= ~2000 * sizeof(int).]
--John
Re: BURT modifications in progress James F. Harrison
Prev: Re: Subroutine record input fields don't get archived William Lupton
Next: Re: NT changes for 3.12.2 Jeff Hill
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: BURT modifications in progress James F. Harrison
Next: description Tim Mooney
