1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: GCC for EPICS Unix code?
To: [email protected]
Date: Mon, 23 Oct 95 09:26:19 HST
Dear all,
>   Does anyone have any experience to report with GCC for building host (Unix)
> EPICS system and / or application code? Good or bad.
Re the above, I had one response from Andrew Johnson citing unexplained
problems with gcc under Solaris. Are there any other Solaris gcc attempters?
What about Linux? Presumably gcc is always used there? Is the lesson that
for system code like EPICS we are best off sticking with the compiler that
compiled the operating system? [is acc used to build SunOS / Solaris?]
  William
Prev: Re: MBBO record support Peregrine McGehee
Next: Re: EPICS status codes proposal Marty Kraimer
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: GCC for EPICS Unix code? William Lupton
Next: Programming the mv162 flash memory for vxWorks winans
