> From [email protected] Thu Oct 19 07:18:00 1995
> Return-Path: <[email protected]>
> Date: Thu, 19 Oct 1995 14:19:44 +0100 (BST)
> To: [email protected]
> Subject: help with ar
> Mime-Version: 1.0
> Content-Type> : > TEXT/PLAIN> ; > charset=US-ASCII>
> Content-Length: 786
> X-Lines: 32
> Hi,
> I've just started to use ar and can't get my script to work properly:
> DESC: test it
> ACT: always
> INACT: never
> TRIGGER: every 0:0:5
> SNAPSHOT: for 1 samples
> OUTPUT: set:txt ar/arSet/test.txt
> %endHeader%
> ser2:emosub_44.VALA
> It validates ok and when added to the main pannel successfully gets its
> first sample: 'snapshot complete...' and data is written to the file. It
> then says: 'snapshot sampling...' but never gets anything. If I ask for
> status|show sampling state it saya: 'snapshot in progress; 0 samples,
> last at 00:00:09.000'
> the ADEL for the record is set to 0.
> Anybody have any ideas?
> thanks
> Ian A Smith Telephone: +44 (0) 131 668 8257
> Royal Observatory Fax: +44 (0) 131 668 1130
> Blackford Hill Web: http://www.roe.ac.uk/
> Edinburgh
> UK
The archiver won't take samples unless ser2:emosub_44.VALA is changing.
I think this is a bug, but it is the way it works. If you
want to take samples where some channels are changing and some are not,
you can put F (for fill) in front of the ones that are not changing .
For example if you have a counter calc record named "counter"
that is being scanned (and changed) more often than once every 5 seconds
the following should get samples
for ser2:emosub_44.VALA as well
DESC: test it
ACT: always
INACT: never
%endHeader%
counter
F ser2:emosub_44.VALA
I hope this helps.
Rozelle
|Rozelle Wright Phone (505) 667-4804 |
|Los Alamos Natl Labs AOT-8 FAX (505) 665-5107 |
|PO Box 1663 MS-H820 Group Office (505) 667-6087|
|Los Alamos, NM 87545 email : [email protected] |
Re: Medm and XRT/Graph Philip Taylor
Re: application error codes Bill Brown
<1995>
help with ar Ian Smith
Re: help with ar Deb Kerstiens
<1995>
