1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: edd/dm
To: [email protected]
Date: Fri, 13 Oct 95 13:46:26 MDT
Ian wrote:
> I have a few problems with edd/dm.  I know that there has been talk about
> this before, but I didn't find much in the archives.  Perhaps someone
> could remind me.  Dm is losing contact with variables in epics
> and the strip chart is terrible, sometimes it doesn't start,
> if it does it doesn't last long, and sometimes it suddenly starts for a
> brief period.  Sound familiar?  My Edd is at v 1.16 and the record
> attached to the strip chart has the MDEL field to -1.
I've asked Ian for more information to try and diagnose the problem
of dm losing contact with variables.  I thought I should respond
globally to the strip chart question since it may be useful to others.
	From the description, it sounds as though the strip chart is only
	changing when it gets a monitor (as would be expected from the way
	the strip chart works.)
	Even if the .MDEL field is set to -1, the chan will still only update
	regularly if the record is processed regularly, i.e. periodic or
	processed from the FLNK of another chan that is processed regularly.
	We have used a trick before to cause updates:  create a soft chan
	that updates periodically, but has constant value such as 0.0.
	In edd, enter this chan as the first in the strip chart.  Then enter
	the real chan(s) in the strip char in edd as "F <channame>".  If one
	channel actually has regular monitors and all others are "Filled",
	the strip chart will update.  Using the extra chan is useful to
	eliminate the need to process the real data channels just to get the
	info on the strip chart. (This also avoids having all dm objects that
	reference the real channel update unnecessarily.)
	The plot package is the one used by the archiver.  Unfortunately, it
	is based on the notion of "synchronous" data which is a throwback
	from the accelerator project for which it was designed (GTA, for
	those of you who know the EPICS history.)  The "F " prefix indicates
	to "fill" the data for that chan , i.e. use the last data gathered for
	that chan regardless of whether it has changed since the last point.
	As Bob stated, the plots are horrible.  It is our intent to create a
	new plot package, but currently we have no funding to do this.
I apologize for any confusion or frustration strip charts and plots may cause
any of you.
Deb
Deb Kerstiens		[email protected]
Phone			(505)667-3396
LANL AOT-8,MSH820	PO Box 1663, Los Alamos, NM. 87545
Prev: Re: edd/dm Bob Dalesio
Next: Re: High speed A/D Carl W. Cork
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: problems building epics Paul Banta
