1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Epics C++ Problems
To: [email protected]
Cc: [email protected]
Date: Fri, 6 Oct 1995 09:10:27 -0500
> and does a typedef with the name chid for this structure.
> Later this name is used in two structures, for example in :
> 	struct	event_handler_args{
> 		void	*usr;	/* User argument supplied when event added 	*/
> --->		chid	chid;	/* Channel id					*/
> 		long	type;	/* the type of the value returned (long aligned)*/
> 		long	count;	/* the element count of the item returned	*/
> 		void 	*dbr;	/* Pointer to the value returned		*/
> 		int	status;	/* CA Status of the op from server - CA V4.1	*/
Olaf,
This problem has already been address and Jeff has corrected it for the
next release, in the mean time, attached is the corrected file.
Jim
-----------------------------cut-----------------------------
#ifndef INCLcadefh
#define INCLcadefh
#ifdef __cplusplus
extern "C" {
#define CAC_FUNC_PROTO
#endif
#include <shareLib.h>
#ifdef __STDC__
#endif
#ifndef HDRVERSIONID
#	define HDRVERSIONID(NAME,VERS)
#endif /*HDRVERSIONID*/
HDRVERSIONID(cadefh, "@(#) $Id: cadef.h,v 1.39 1995/09/29 21:35:06 jhill Exp $")
/* auto include of all stuff that cadef.h uses */
#if defined(CAC_FUNC_PROTO) && !defined(CA_DONT_INCLUDE_STDARGH)
#include <stdarg.h>
#endif
#ifndef INCLdb_accessh
#include <db_access.h>
#endif /* INCLdb_accessh */
#ifndef INCLcaerrh
#include <caerr.h>
#endif /* INCLcaerrh */
#ifndef INCLcaeventmaskh
#include <caeventmask.h>
#endif /* INCLcaeventmaskh */
#ifndef INCLellLibh
#include <ellLib.h>
#endif /* INCLellLibh */
 *	NOTE: the channel in use fields type, count, name, and
 *	host name are available to applications. However it is
 *	recommended that the following MACROS be used to access them.
#define ca_field_type(CHID)     	((CHID)->type)
#define ca_element_count(CHID)   	((CHID)->count)
#define ca_name(CHID)           	((char *)((CHID)+1))
#define ca_puser(CHID)           	((CHID)->puser)
#define ca_host_name(CHID)           	ca_host_name_function(CHID)
#define ca_read_access(CHID)		((CHID)->ar.read_access)
#define ca_write_access(CHID)		((CHID)->ar.write_access)
 *	cs_ - `channel state'
 *	cs_never_conn		valid chid, IOC not found
 * 	cs_prev_conn		valid chid, IOC was found, but unavailable
 *	cs_conn			valid chid, IOC was found, still available
 * 	cs_closed		invalid chid
enum channel_state{cs_never_conn, cs_prev_conn, cs_conn, cs_closed};
#define ca_state(CHID)           	((CHID)->state)
typedef struct ca_access_rights{
	unsigned	read_access:1;
	unsigned	write_access:1;
}caar;
/* Format for the arguments to user connection handlers 		*/
struct	connection_handler_args{
	struct channel_in_use	*chid;	/* Channel id	 		*/
	long			op;	/* External codes for CA op	*/
#ifdef CAC_FUNC_PROTO
typedef void caCh(struct connection_handler_args args);
#else /*CAC_FUNC_PROTO*/
typedef void caCh();
#endif /*CAC_FUNC_PROTO*/
/* Format for the arguments to user access rights handlers 		*/
struct	access_rights_handler_args{
	caar			ar;	/* New access rights state	*/
typedef void caArh(struct access_rights_handler_args args);
typedef void caArh();
struct channel_in_use{
	ELLNODE			node;	/* list ptrs			*/
	short			type;	/* database field type 		*/
#define TYPENOTCONN	(-1)		/* the type when disconnected	*/
	unsigned short		count;	/* array element count 		*/
	union{
	  unsigned 		sid;	/* server id			*/
	  struct db_addr	*paddr;	/* database address		*/
	}			id;
	void			*puser;	/* user available area		*/
	enum channel_state	state;	/* connected/ disconnected etc	*/
	caar			ar;	/* access rights		*/
	 *	The following fields may change or even vanish in the future
	caCh			*pConnFunc;
	caArh			*pAccessRightsFunc;
	ELLLIST			eventq;
	unsigned 		cid;	/* client id */
	unsigned		retry;	/* search retry number */
	void			*piiu;	/* private ioc in use block */
#ifdef vxWorks
	void			*ppn;  /* ptr to optional put notify blk */
#endif /* vxWorks */
	 * channel name stored directly after this structure in a
	 * null terminated string.
typedef	struct channel_in_use	*chid;
typedef long			chtype;
typedef	struct pending_event	*evid;
typedef double			ca_real;
/*	The conversion routine to call for each type	*/
#define VALID_TYPE(TYPE)  (((unsigned short)TYPE)<=LAST_BUFFER_TYPE)
/* argument passed to event handlers and callback handlers		*/
	long			type;	/* the type of the value returned		*/
struct pending_event{
  	void			(*usr_func)(struct  event_handler_args args);
  	void			(*usr_func)();
  	void			*usr_arg;
  	struct channel_in_use 	*chan;
  	chtype			type;	/* requested type for local CA	*/
  	unsigned long		count;	/* requested count for local CA */
	 * the following provide for reissuing a
	 * disconnected monitor
  	ca_real			p_delta;
  	ca_real			n_delta;
  	ca_real			timeout;
	unsigned		id;
  	unsigned short		mask;
void epicsShareAPI ca_test_event
/* Format for the arguments to user exception handlers 			*/
struct	exception_handler_args{
	long 			type;	/* Requested type for the operation		*/
	long 			count;	/* Requested count for the operation		*/
	void 			*addr;	/* User's address to write results of CA_OP_GET	*/
	long			stat;	/* Channel access std status code 		*/
	long			op;	/* External codes for channel access operations	*/
	char			*ctx;	/* A character string containing context info	*/
 *	External OP codes for CA operations
#define CA_OP_GET 		0
#define CA_OP_PUT 		1
#define CA_OP_SEARCH 		2
#define CA_OP_ADD_EVENT 	3
#define CA_OP_CLEAR_EVENT 	4
#define CA_OP_OTHER 		5
#define CA_OP_CONN_UP 		6
#define CA_OP_CONN_DOWN 	7
/*	Perform Library Initialization					*/
/*	Must be called once before calling any of the other routines	*/
int epicsShareAPI ca_task_initialize
	void
/*	Remove CA facility from your task				*/
/*	Normally called automatically at task exit			*/
int epicsShareAPI ca_task_exit
	void
/*	Return a channel identification for the supplied channel name	*/
/*	(and attempt to create a virtual circuit)			*/
 * preferred search mechanism
#define ca_search(NAME,CHIDPTR)\
ca_search_and_connect(NAME, CHIDPTR, 0, 0)
/*	ca_search
		Name	IO	Value
char *,	 	NAME	R	NULL term ASCII channel name string
chid *	 	CHIDPTR	RW	channel index written here
 * anachronistic entry points						*
 * **** Fetching a value while searching nolonger supported****		*
#define ca_build_channel(NAME,XXXXX,CHIDPTR,YYYYY)\
ca_build_and_connect(NAME, XXXXX, 1, CHIDPTR, YYYYY, 0, 0)
#define ca_array_build(NAME,XXXXX, ZZZZZZ, CHIDPTR,YYYYY)\
ca_build_and_connect(NAME, XXXXX, ZZZZZZ, CHIDPTR, YYYYY, 0, 0)
int epicsShareAPI ca_search_and_connect
	/*	Name	IO	Value					*/
char *,/* 	NAME	R	NULL term ASCII channel name string	*/
chid *,/* 	CHIDPTR	RW	channel index written here		*/
void (*)(struct connection_handler_args),
	/*	PFUNC	R	the address of user's connection handler*/
void * 	/*	PUSER	R	placed in the channel's puser field 	*/
 * anachronistic entry point						*
int epicsShareAPI ca_build_and_connect
	/*	Name	IO	Value					*/
char *,	/* 	NAME	R	NULL term ASCII channel name string	*/
chtype,	/*	GET_TYPE R 	external channel type to get		*/
unsigned/*			(no get if invalid type)		*/
long,	/*	GET_COUNT R	array count to get			*/
chid *,	/* 	CHIDPTR	RW	channel index written here		*/
void *,	/*	PVALUE	W	A pointer to a user supplied buffer	*/
int epicsShareAPI ca_change_connection_event
chid	chix,
void	(*pfunc)(struct connection_handler_args)
int epicsShareAPI ca_replace_access_rights_event(
chid	chix,
void 	(*pfunc)(struct access_rights_handler_args)
 * replace the default exception handler
int epicsShareAPI ca_add_exception_event
void            (*pfunc)(struct exception_handler_args),
void            *arg
/*	deallocate resources reserved for a channel			*/
int epicsShareAPI ca_clear_channel
	/*      Name    IO      Value					*/
chid	/*	CHAN,	R	channel identifier			*/
/*	Write a value to a channel					*/
#define	ca_bput(CHID,PVALUE)  	ca_array_put(DBR_STRING, 1, CHID, (PVALUE))
C Type		Name	IO	Value
chid	 	CHID	R	channel id
char *	 	PVALUE	R	pointer to a binary value string
#define	ca_rput(CHID,PVALUE)\
ca_array_put(DBR_FLOAT, 1, CHID, (PVALUE))
dbr_float_t *	PVALUE	R	pointer to a real value
#define ca_put(CHTYPE, CHID, PVALUE) ca_array_put(CHTYPE, 1, CHID, PVALUE)
		Name	IO	Value
chtype,		TYPE	R	channel type
chid,	 	CHID	R	channel index
void *		PVALUE	R	pointer to new channel value of type specified
				i.e. status = ca_put(DBF_INT,chid,&value)
int epicsShareAPI ca_array_put
	/*	Name	IO	Value					*/
chtype,	/*	TYPE	R	channel type				*/
unsigned long,
	/*	COUNT	R	array element count			*/
chid,	/* 	CHID	R	channel index	 			*/
void *	/*	PVALUE	R	pointer to new channel value of type	*/
	/*			specified.				*/
 * This routine functions identically to the original ca put request
 * with the addition of a callback to the user supplied function
 * after recod processing completes in the IOC. The arguments
 * to the user supplied callback function are declared in
 * the structure event_handler_args and include the pointer
 * sized user argument supplied when ca_array_get_callback() is called.
int epicsShareAPI ca_array_put_callback
        /*      Name    IO      Value                                   */
unsigned long,
void *, /*      PVALUE  R       pointer to new channel value of type    */
void (*)(struct event_handler_args),
        /*      USRFUNC R       the address of a user supplied function */
void *  /*      USRARG  R       An argument copied to the above function*/
/*	Read a value from a channel					*/
#define	ca_bget(CHID,PVALUE)  	ca_array_get(DBR_STRING, 1, CHID, PVALUE)
char *	 	PVALUE	W	string value pointer
#define	ca_rget(CHID,PVALUE)  	ca_array_get(DBR_FLOAT, 1, CHID, PVALUE)
dbr_float_t *	PVALUE	W	real value pointer
#define ca_get(CHTYPE, CHID, PVALUE) ca_array_get(CHTYPE, 1, CHID, PVALUE)
void *		PVALUE	W	ptr to where channel value written
int epicsShareAPI ca_array_get
	/*	Name	IO	Value					*/
unsigned long,
void *	/*	PVALUE	W	ptr to where channel value written	*/
/*	Read a value from a channel and run a callback when the value	*/
/*	returns								*/
#define	ca_bget_callback(CHID,PFUNC,ARG)\
ca_array_get_callback(DBR_STRING, 1, CHID, PFUNC, ARG)
void (*)(),	PFUNC	R	the address of a user supplied function
void *,		ARG	R	An argument copied to the above function
#define	ca_rget_callback(CHID,PFUNC,ARG)\
ca_array_get_callback(DBR_FLOAT, 1, CHID, PFUNC, ARG)
#define	ca_get_callback(CHTYPE, CHID,PFUNC,ARG)\
ca_array_get_callback(CHTYPE, 1, CHID, PFUNC, ARG)
int epicsShareAPI ca_array_get_callback
	/*	Name	IO	Value					*/
unsigned long,
void *	/*	USRARG	R	An argument copied to the above function	*/
/*	Specify a function to be executed whenever significant changes	*/
/*	occur to a channel.						*/
/*	NOTES:								*/
/*	1)	Evid may be omited by passing a NULL pointer		*/
/*	2)	AN array count of zero specifies the native db count	*/
typedef struct event_handler_args  evargs;
/*	Assumes DELTA info comes from the database or defaults		*/
#define ca_add_event(TYPE,CHID,ENTRY,ARG,EVID)\
ca_add_array_event(TYPE,1,CHID,ENTRY,ARG,0.0,0.0,0.0,EVID)
/*		Name	IO	Value
void
(*)(),		USRFUNC	R	the address of a user supplied function
void *,		USRARG	R	An argument copied to the above function
evid *  	EVIDPTR	W	An id to refer to this event by
/*	Sets both P_DELTA and M_DELTA below to argument DELTA		*/
#define ca_add_delta_event(TYPE,CHID,ENTRY,ARG,DELTA,EVID)\
	ca_add_array_event(TYPE,1,CHID,ENTRY,ARG,DELTA,DELTA,0.0,EVID)
/*		Name	IO	Value
void
ca_real,	DELTA	R	Generate events after +-delta excursions
#define ca_add_general_event(TYPE,CHID,ENTRY,ARG,P_DELTA,N_DELTA,TO,EVID)\
ca_add_array_event(TYPE,1,CHID,ENTRY,ARG,P_DELTA,N_DELTA,TO,EVID)
#define	ca_add_array_event(TYPE,COUNT,CHID,ENTRY,ARG,P_DELTA,N_DELTA,TO,EVID)\
ca_add_masked_array_event(TYPE,COUNT,CHID,ENTRY,ARG,P_DELTA,N_DELTA,TO,EVID, DBE_VALUE | DBE_ALARM)
int epicsShareAPI ca_add_masked_array_event
	/*	Name	IO	Value					*/
chtype,	/*	TYPE	R	requested external channel type		*/
unsigned long,
void *,	/*	USRARG	R	An argument copied to the above function*/
ca_real,/*	P_DELTA	R	Generate events after +delta excursions	*/
ca_real,/*	N_DELTA	R	Generate events after -delta excursions	*/
ca_real,/*	TIMEOUT	R	Generate events after timeout sec	*/
evid *, /*	EVIDPTR	W	An id to refer to this event by		*/
long	/*	MASK	R	event trigger type			*/
/*	Remove a function from a list of those specified to run 	*/
/*	whenever significant changes occur to a channel			*/
int epicsShareAPI ca_clear_event
	/*	Name	IO	Value					*/
evid	/* 	EVID	R	Event id returned by add event		*/
/*	 Requested data is not necessarily stable prior to		*/
/*	 return from called subroutine.  Call ca_pend_io()		*/
/*	 to guarantee that requested data is stable.  Call the routine	*/
/*	 ca_flush_io() to force all outstanding subroutine calls to be	*/
/*	 sent out over the network.  Significant increases in 		*/
/*	 performance have been measured when batching several remote 	*/
/*	 subroutine calls together into one message.  Additional	*/
/*	 improvements can be obtained by performing local processing	*/
/*	 in parallel with outstanding remote processing.		*/
/*	 FLOW OF TYPICAL APPLICATION					*/
/*	 search()		! Obtain Channel ids			*/
/*	 get()			! several requests for remote info	*/
/*	 get()			! "					*/
/*	 add_event()		! "					*/
/*	 get()			! "					*/
/*	 flush_io()		! send get requests			*/
/*				! optional parallel processing		*/
/*	 pend_io()		! wait for replies from get requests	*/
/*	 .			! access to requested data 		*/
/*	 pend_event()		! wait for requested events  		*/
/*	This routine pends waiting for channel events and calls the 	*/
/*	functions specified with add_event when events occur. If the 	*/
/*	timeout is specified as 0 an infinite timeout is assumed.	*/
/*	if the argument early is specified TRUE then CA_NORMAL is 	*/
/*	returned when outstanding queries complete. Otherwise if the 	*/
/*	argument early is FALSE the routine does not return until the 	*/
/*	entire delay specified by the timeout argument has expired.	*/
/*	ca_flush_io() is called by this routine. If the argument	*/
/*	early is TRUE then ca_pend() will return immediately without	*/
/* 	processing outstanding CA labor if no queries are outstanding	*/
#define ca_pend_event(TIMEOUT) ca_pend((TIMEOUT), 0/*FALSE*/)
#define ca_pend_io(TIMEOUT) ca_pend((TIMEOUT), 1/*TRUE*/)
int epicsShareAPI ca_pend
	/*	Name	IO	Value					*/
ca_real,/*	TIMEOUT	R	timeout in seconds			*/
int	/*	EARLY	R	return early if IO completes		*/
 * returns TRUE when queries are outstanding
int epicsShareAPI ca_test_io
        /*      Name    IO      Value                                   */
void
/*	Send out all outstanding messages in the send queue		*/
int epicsShareAPI ca_flush_io
	void
void epicsShareAPI ca_signal
	/*	Name	IO	Value						*/
long,	/*	CODE	R	status returned from channel access function	*/
char *	/*	MSG	R	null term string printed on error		*/
void epicsShareAPI ca_signal_with_file_and_lineno
        /*      Name    IO      Value                                           */
char *,	/*	MSG	R       null term string printed on error               */
char *,	/*	FILE	R	pointer to null terminated file name string	*/
int	/*	LINENO	R	line number					*/
 *	Provided for efficient test and display of channel access errors
#define		SEVCHK(CA_ERROR_CODE, MESSAGE_STRING) \
	int ca_unique_status_name  = (CA_ERROR_CODE); \
	if(!(ca_unique_status_name & CA_M_SUCCESS)) \
		ca_signal_with_file_and_lineno( \
			ca_unique_status_name, \
			(MESSAGE_STRING), \
			__FILE__, \
			__LINE__); \
char * epicsShareAPI ca_host_name_function
	/*	Name	IO	Value					*/
chid	/*	CHID	R	Channel ID				*/
 *      CA_ADD_FD_REGISTRATION
 *      call their function with their argument whenever
 *	a new fd is added or removed
 *      (for use with a manager of the select system call under UNIX)
typedef void CAFDHANDLER(void *parg, int fd, int opened);
typedef void CAFDHANDLER();
int epicsShareAPI ca_add_fd_registration(
CAFDHANDLER 	*pHandler,
void    	*pArg
#ifdef vxWorks
int epicsShareAPI ca_channel_status(
int tid
#endif
#ifdef vxWorks
int ca_import(int tid);
int ca_import();
#ifdef vxWorks
int ca_import_cancel(int tid);
int ca_import_cancel();
 * CA synch groups
 * This facility will allow the programmer to create
 * any number of synchronization groups. The programmer might then
 * interleave IO requests within any of the groups. Once The
 * IO operations are initiated then the programmer is free to
 * block for IO completion within any one of the groups as needed.
typedef unsigned WRITEABLE_CA_SYNC_GID;
typedef const unsigned CA_SYNC_GID;
#else
typedef unsigned CA_SYNC_GID;
#endif
 * create a sync group
int epicsShareAPI ca_sg_create(
CA_SYNC_GID *pgid
 * delete a sync group
int epicsShareAPI ca_sg_delete(
CA_SYNC_GID gid
 * block for IO performed within a sync group to complete
int epicsShareAPI ca_sg_block(
CA_SYNC_GID gid,
ca_real timeout
 * test for sync group IO operations in progress
int epicsShareAPI ca_sg_test(
CA_SYNC_GID gid
 * ca_sg_reset
int epicsShareAPI ca_sg_reset(
CA_SYNC_GID gid
 * initiate a get within a sync group
 * (essentially a ca_array_get() with a sync group specified)
int epicsShareAPI ca_sg_array_get
        /*      Name    IO      Value                                   */
CA_SYNC_GID,/*  GID     R       synch group id                          */
unsigned long,
 * initiate a put within a sync group
 * (essentially a ca_array_put() with a sync group specified)
int epicsShareAPI ca_sg_array_put
        /*      Name    IO      Value                                   */
unsigned long,
        /*                      specified.                              */
 * CA_MODIFY_USER_NAME()
 * Modify or override the default
 * client user name.
int epicsShareAPI ca_modify_user_name(char *pUserName);
int epicsShareAPI ca_modify_user_name();
 * CA_MODIFY_HOST_NAME()
 * client host name.
int epicsShareAPI ca_modify_host_name(char *pHostName);
int epicsShareAPI ca_modify_host_name();
 * Put call back is available if the CA server is on version is 4.2
 *	or higher.
 * (return true or false)
int epicsShareAPI ca_v42_ok(chid chan);
int epicsShareAPI ca_v42_ok();
 * ca_replace_printf_handler ()
 * for apps that want to change where ca formatted
 * text output goes
int epicsShareAPI ca_replace_printf_handler (
int (*ca_printf_func)(const char *pformat, va_list args)
int epicsShareAPI ca_replace_printf_handler ();
#ifdef __cplusplus
#endif
 *	no additions below this endif
#endif /* INCLcadefh */
Prev: What th??? (was: Re: Epics C++ Problems) John R. Winans
Next: EPICS RS232 Ian Smith
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Epics C++ Problems John R. Winans
Next: Re: Epics C++ Problems Jeff Hill
