1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Epics C++ Problems
To: [email protected]
Date: Fri, 06 Oct 1995 13:35:07 +0100
Hello Together
I have the following problem with the EPICS cadef.h file:
This .h file defines the following structure
	struct channel_in_use{
		ELLNODE			node;	/* list ptrs			*/
		short			type;	/* database field type 		*/
	#define TYPENOTCONN	(-1)		/* the type when disconnected	*/
		unsigned short		count;	/* array element count 		*/
		union{
		  unsigned 		sid;	/* server id			*/
		  struct db_addr	*paddr;	/* database address		*/
		}			id;
		void			*puser;	/* user available area		*/
		enum channel_state	state;	/* connected/ disconnected etc	*/
		caar			ar;	/* access rights		*/
		 *	The following fields may change or even vanish in the future
		caCh			*pConnFunc;
		caArh			*pAccessRightsFunc;
		ELLLIST			eventq;
		unsigned 		cid;	/* client id */
		unsigned		retry;	/* search retry number */
		void			*piiu;	/* private ioc in use block */
	#ifdef vxWorks
		void			*ppn;  /* ptr to optional put notify blk */
	#endif /* vxWorks */
		 * channel name stored directly after this structure in a
		 * null terminated string.
	typedef	struct channel_in_use	*chid;
and does a typedef with the name chid for this structure.
Later this name is used in two structures, for example in :
	struct	event_handler_args{
		void	*usr;	/* User argument supplied when event added 	*/
--->		chid	chid;	/* Channel id					*/
		long	type;	/* the type of the value returned (long aligned)*/
		long	count;	/* the element count of the item returned	*/
		void 	*dbr;	/* Pointer to the value returned		*/
		int	status;	/* CA Status of the op from server - CA V4.1	*/
This gives this warning with the SUN compiler:
"./epics.3.12.1/base/include/cadef.h", line 218: Warning (Anachronism): Redefining chid after use in event_handler_args.
"./epics.3.12.1/base/include/cadef.h", line 218: Note: Type "CC -migration" for more on anachronisms.
"./epics.3.12.1/base/include/cadef.h", line 257: Warning (Anachronism): Redefining chid after use in exception_handler_args.
and even worse it is a syntax error! with GNU g++ compiler
It compiles, when the name is changed. e.g. chid chidname
Can somebody help me ?!
 ***  **** ** *   *    Olaf Hensler
 *  * *   *    * *     DESY, -MVP-        [email protected]
 *  * ***  **   *      Notkestrasse 85    Tel.: +49 40 8998 3372
 *  * *      *  *      22603 Hamburg      FAX : +49 40 8998 4448
 ***  **** **   *      Germany
Prev: Re: InterViews and free_gdct for Solaris jbk
Next: Re: Epics C++ Problems John R. Winans
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
