1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Q: NI-1014 GPIB board with Force CPU40.
To: Noboru Yamamoto <[email protected]>
Cc: [email protected], [email protected], Kazuro FURUKAWA <[email protected]>
Date: Mon, 18 Sep 95 17:14:26 +0900
Hello Yamamoto-san,
I'm sorry for my late message.
>>> In message <[email protected]> ,  Noboru Yamamoto <[email protected]>  wrote;
> After I sent a question to tech-talk, we found the following fact:
> 	1) NI-1014 DMA can access VME address in A24 mode.
> 	2) To accesse Main memory on FORCE cpu40 via VME bus, address mode
> should be A32 mode.
> These facts  means that the standard GPIB support routines in EPICS does not
> work for this combination of boards. We happened to have memory board for VME
> bus and allocated buffer space GPIB driver on this memory board. After that,
> GPIB support routines are working.
Force CPU40 has A24 slave capability, while CPU30 does not.
Actually the A24 slave capability is implemented on an external
circuit outside VME gate array (FGA-002) for CPU30/40.  Thus
it isn't explained in the documentation of FGA-002 but in one
of CPU-40.
I use this sort of code fragment (on OS9) to initialize A24
slave access for A24 DMA.
	p = (uchar *)0xff800c00;	/* pointer to PI/T1 */
	*(p+0x03) = 0xff;		/* PB all output,        PBDDR */
	*(p+0x09) = 0x80;		/* upper address in A24, PBDR */
	p = (uchar *)0xff800e00;	/* pointer to PI/T2 */
	*(p+0x04) = 0xa8;		/* PC7 output,           PCDDR */
	*(p+0x0c) = 0x7e;		/* enable A24 slave,     PCDR */
This way, you may eliminate an external memory board.
Regards, Kazuro.
古川 和朗,  Kazuro FURUKAWA,  KEK-Linac  <[email protected]>
 Natl. Lab. for High Energy Physics (KEK), Japan
 Telephone: +81-298-64-5694,  Facsimile: +81-298-64-7529
Re: Q: NI-1014 GPIB board with Force CPU40. Noboru Yamamoto
Prev: Re: BURT modifications watson
Next: RE: RS232 Matthias Clausen DESY -MKV2/KRYK-
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Q: NI-1014 GPIB board with Force CPU40. Noboru Yamamoto
Next: Re: Q: NI-1014 GPIB board with Force CPU40. Noboru Yamamoto
