1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Bug in command line shell caget
To: [email protected]
Date: Wed, 2 Aug 1995 11:52:26 -0500
The problem of accessing float arrays > 4000 and double > 2000 with
the shell command "caget" has been fixed.
The limitation of array size is removed from the caget. Now it is
limited by the real CA size (currently it is 16K).
A new option of "-# n" on the command line is added. This option
applies only to the array type of record. It allows the user to
get the first "n" values for the array record.  If the "-# n"
option is not used then the whole array is returned.
Prev: re: Hardware Supported by EPICS Matthias Clausen DESY -MKV2/KRYK-
Next: default.dctsdr Marty Kraimer
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Bug in command line shell caget Frank Lenkszus
Next: Epics and Linux jpq
