1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: re: Hardware Supported by EPICS
From: Matthias Clausen DESY -MKV2/KRYK- <[email protected]>
To: [email protected]
Cc: [email protected]
Date: Wed, 02 Aug 1995 11:35:47 EDT
>One of the VME crates should provide up to 15 serial interfaces (RS-232)
>and 10-12 analog inputs. However, we were wondering which VME boards or
>modules are supported by EPICS. The List of Supported Hardware distributed
>through the ANL WWW server seems to be somewhat out of date (1993).
You might do this job with a single 162 if you choose:
	2 IP-OCTAL (Green-Spring)
	1 32 channel A/D from Acromag or any other ...
In case you might need additionel signals like DIN's and DOT's an D to A
you might be better off with the IRM from Fermilab which covers all the
direct I/O and you still can add two IP-OCTAL's to handle the serial lines.
Drivers for the IP-OCTAL come with the IP-module, EPICS support for these
can be obtained from us. IRM driver are also available from us.
Regards
Matthias
	Matthias Clausen		Deutsches Elektronen Synchrotron
	Gruppe: MKV2/KRYK		       DESY/Hamburg, Germany
Prev: Re: error in compiling xmca Ben-chin K. Cha
Next: Re: Bug in command line shell caget Ben-chin K. Cha
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Hardware Supported by EPICS winans
Next: Re: Hardware Supported by EPICS Steve Lewis
