1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: OMS driver bug?
To: [email protected]
Date: Fri, 28 Jul 1995 14:19:30 +0100 (BST)
I'm experiencing some strange effects when I have the ACCL field set to
say around 6 seconds, though 3 seconds also exhibts the effect.  If I
request a small move the motor moves but the MPOS field doesn't update.
If I asked it to go to the same position the motor moves a bit more and
MPOS updates.  If I ask a 3rd time the motor doesn't move but MPOS updates
to 2x the original distance.  If I ask a 4th time the motor moves back to
where it should be and MPOS is continuously updated. ie:
Demand Position		Position		MPOS
92000			92000			92000 1st (long) move, ok
92050			92050			92000 move ok, frozen MPOS
92050			92100			92050 unexpect 2nd move
92050			92100			92100 no move, MPOS updates
92050			92050			92050 motor moves back,
						      MPOS continuously updates
If I set the ACCL parameter to 1 second then everything behaves as one
would expect.  The other parameters are:
OMSL supervisory	VELO 1.5	MRES 1000	RTRY 0
Any ideas before I dive into the code?  The problem could of course be in
the OMS firmware.
Ian A Smith			Telephone: +44 (0) 131 668 8257
Royal Observatory		Fax:       +44 (0) 131 668 1130
Blackford Hill			Web:       http://www.roe.ac.uk/
Edinburgh
UK
Prev: Re: Cute error in alh/file.c Marty Kraimer
Next: OMS driver bug? (re-send) Ian Smith
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Announcing ezcaIDL, a new extension Mark Rivers
