1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re:EPICS_CA_ADDR_LIST in R3.12Beta13CEBAF
To: [email protected]
Date: Thu, 20 Jul 1995 11:49:18 +0900
In >Message-Id: <[email protected]>,
>From: Johnny Tang <[email protected]>
wrote,
>Subject: CA-ADDR-LIST
>Date: Mon, 17 Jul 95 10:41:11 EDT
>Johnny Tang     Voice: (804)249-7239  E-Mail: [email protected]
>Continous Electron Beam Accelerator Facility
>12000 Jefferson Avernue, MS 85A
>Newport News, Va 23606
>Mailer: Elm [revision: 70.85]
>> Hi,
>>  Does anyone use EPICS_CA_ADDR_LIST environment variable in R3.12Beta13?
>> I installed R3.12.0Beta13CEBAF on our HP-WS. ca_test cannot find a channel
>> on IOC. The older version of ca_test , which also uses EPICS_CA_ADDR_LIST
>> variable , can find the channel. In our configuration, IOC's and OPI's
>> belong differenct sub-nets and channel search by bradcast will not work.
>>  Thank you for your help,
>>   Noboru Yamamoto
>>   KEKB accelerator control group.
>>   KEK, JAPAN
>  Since IOC's and OPI's in different sub-net in your configuration,
>you need set EPICS_CA_ADDR_LIST invironment variable. For more detail,
>refer "EPICS R3.12 Channel Access Reference Manual" which  you can
>get from APS WWW.
Yes. I set up "EPICS_CA_ADDR_LIST" but still ca_test in R312Beta13 could
not find the channel. ca_test from older version R312Beta0 can find the
channel when  "EPICS_CA_ADDR_LIST" is set up, however.
>  R3.12.0Beta13CEBAF is CEBAF local customized (in devSup, recSup) version
>of R3.12.0Beta13 from APS CVS server. They should be no difference in
>channel access.
>  --- Johnny Tang
>      CEBAF
>From: [email protected] (Jeff Hill)
wrote,
>Hello,
>I just sent a bug report to the EPICS exploder which is indirectly related
>to EPICS_CA_ADDR_LIST. I suspect however that this may not be your problem.
>Here are a few things to check:
>o Does the UNIX work station have a route to the IOC?
>       (type netstat -r under UNIX)
Yes. IOC and WS can talk to each other with TCP/IP.
>o Type "CASDEBUG=10" on the IOC. This will show too much detail about
>       the messages received by the CA server. However it may be
>       useful to see if your search requests are being processed by
>       the server. Typing "CASDEBUG=0" will turn off the flood of
>       messages.
When I used ca_test in R312Beta13 , no output was produced on IOC.
Older ca_test  produced a lot.
>o Type "client_stat" on the IOC and check to see if the address list
>       used by the server matches the EPICS_CA_ADDR_LIST you have
EPICS_CA_ADDR_LIST on IOC keeps just broad cast address of the sub-network
on which IOC's are connected. Shoud it includes IP addresses of the
OPI's as well?
>       specified. Watch the output from ioc_init for possible syntax
>       errors in the resource definition file.
>o Use a network sniffer such as etherfind or tcpdump. I often find
>       that the command "etherfind -proto udp dstport 5064"
>       provides useful information about who is sending search
>       requests (5064 is the default port for UDP CA search requests).
>       Note that it is best to use a different machine than the
>       one running the client that you are observing.
I don't have both of them on our HP-WS. I'm going to install them.
>That is all I can think of at the moment. If you are still having
>problems let me know and I will examine your situation in more
>detail.
>Jeff
Thank both of you for your help.
Noboru
Prev: joining the action Sarah Quady
Next: SDR files for multiple platforms greene%denali.UUCP
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: EPICS_CA_ADDR_LIST in R3.12Beta13CEBAF Jeff Hill
Next: Re:EPICS_CA_ADDR_LIST in R3.12Beta13CEBAF Jeff Hill
