1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Internal type conversion in Epics
To: Epics Questions <[email protected]>
Date: Wed, 19 Jul 1995 15:08:01 +0100 (BST)
Marty,
Thanks for your reply concerning the accuracy of
converting a Double to a String within EPICS.
I have done some further investigation and found that
by setting PREC to 7 in the incoming record (the record
which is receiving the double), I do indeed get an accuracy
of 7 decimal places. However, changing PREC to 15 (which you
might want for the accuracy of a double),
I discovered that the double goes through with an
accuracy of only 5 decimal places!
The problem lies within the code for "cvtDoubleToString" inside
libCom/cvtFast.c. Line 150 of cvtFast.c shows that the value will
be converted to a string as follows, whenever PREC > 8.
sprintf(pstr_value,"%12.5e\0",flt_value);
I would say that "%12.5e" format is not what we want in
this case. Are there any plans to change this to something
which greater reflects the accuracy expected of a double?
Andy
Andy Foster
Royal Greenwich Observatory		Tel:    44 (0)1223 374899 (direct)
Madingley Road				E-mail: [email protected]
Cambridge
CB3 0HA
UK
Prev: Re: AO rec flaw Marty Kraimer
Next: Re: Internal type conversion in Epics Marty Kraimer
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Internal type conversion in Epics Marty Kraimer
