1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Solaris 5.x changes to blderrSymTbl
To: [email protected]
Date: Fri, 16 Jun 95 11:26:15 HST
> If you look at Beta13 you'll see that I already fixed this, and in fact Nick
> Rees added to my changes as well since.  It now uses a case on the configured
> HOST_ARCH to split up the different architectures, and with Nick's changes it
> can also take the HOST_ARCH as a parameter.  I'm not sure if Janet has applied
> Nick's changes to the repository yet, but the Beta13 version works in normal
> circumstances (it fails if you are using multiple host architectures and you run
> it on a different architecture to the HOST_ARCH setting in CONFIG_SITE).
Note that my changes to blderrSymTbl are not required if the HostArch
shell script is used to determine HOST_ARCH - Andrews original
version works OK, and is cleaner. Alternatively it can use the HostArch
script directly instead of using `GetVar HOST_ARCH`.
Nick Rees
Joint Astronomy Centre                    Ph:       +1 (808) 961-3756
660 N. Aohoku Place                       Fax:      +1 (808) 961-6516
Hilo, HI.  96720                          Internet: [email protected]
Prev: Re: TTL --> fibre Bill McDowell
Next: e2sr name mangling William Lupton
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Solaris 5.x changes to blderrSymTbl Andrew Johnson
