> From [email protected] Thu Jun 15 21:26 CDT 1995
> Date: Thu, 15 Jun 95 19:26:50 PDT
> From: [email protected] (Michael Bordua)
> To: [email protected], [email protected]
> Subject: Re: Building for more than one host architecture
> Content-Type> : > text>
> Content-Length: 1588
> At LBL we address the above problem by building base and extensions in
> the same sub-directory and then linking to both base and extensions in
> the appication areas. That way if there is some weird dependancy to a
> version of either base or extensions then there is no problem.
Just some additional comments about problems with extensions.
When an application is large, i.e. many iocs and many developers, there will
be periods when iocs are on different releases. This is typically the case
when converting to a new release. In general not all developers are prepared
to convert at the same time. Thus we have extensions users that are talking to
collections of iocs that are using a combination of releases.
This is why Jeff has worked so hard to keep the Channel Access protocal
backwards compatible. When the day comes that the CA protocal is changed
so that backwards compatibility is not supported it will mean that entire
applications must change to the new release. For example at APS it will mean
that all iocs and all extensions products will have to be changed at the
same time.
One last comment. Many users and developers are only involved with extension
products. Thus they dont know or care about base other than that their
extension products happen to be build against a particular version of base.
Marty Kraimer
Re: Solaris 5.x changes to blderrSymTbl Andrew Johnson
Re: TTL --> fibre Bill McDowell
<1995>
Re: Building for more than one host architecture Marty Kraimer
Building for more than one host architecture Janet B. Anderson
<1995>
