1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Building for more than one host architecture
To: tech-talk@phoebus
Date: Wed, 14 Jun 1995 08:12:25 -0500
> From [email protected] Tue Jun 13 15:53 CDT 1995
> To: [email protected] (Marty Kraimer)
> Cc: [email protected]
> Date: Tue, 13 Jun 95 16:53:01 -0400
> From: [email protected]
> X-Mts: smtp
> Content-Type> : > text>
> Content-Length: 395
> >But doesnt this mean that everytime an application developer
> >changes to a new application directory he/she has to make sure it is on the
> >same release or else has to type "setup epics3_12".
> I stand corrected: "." relative path is better for application developers.
> But I still prefer not using /usr/local/epics (which, after all, is a
> single version/release of epics just like $EPICS).
> Chip
Let me give some arguments why we want a directory such as /usr/local/epics
(again there is no magic about /usr/local. It could be any directory).
Each epics developer and each epics user has to have some definitions
(environment variables,etc) created for him/her. In addition there may
be additional release independent epics files needed. By creating a
directory /(something)/epics the only time the epics system manager needs
to interact with the unix system manager is to create the directory.
The owner of the directory should be the epics system manager. Only
release independent files should be placed in this directory. Again only
release independent definitions should be placed in this directory.
In order to use epics, the only thing user should have to do is place a
single command in his/her .cshrc (or similar file for other shells).
At aps this command is
    source /usr/local/etc/Cshrc.aps
which happens to contain the command
    source /usr/local/etc/setup/EPICS
By doing this the epics system manager can make changes to setup environment
without requiring all users to modify their .cshrc files.
An additional comment:
I think that we currently have quite good techniques for providing access to
multiple releases of base. Allowing users access to multiple versions of
extension products is not as convienent. See the EPICS S/R release manual
for current techniques. We had a lot of discussion on this topic but no one
could think of a "perfect" solution.
Marty Kraimer
Prev: Re: Building for more than one host architecture watson
Next: Re: application directories and CVS, GNU make etc Marty Kraimer
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Building for more than one host architecture Marty Kraimer
