1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Analog Output Record Bug
To: [email protected]
Date: Mon, 12 Jun 95 15:25:49 MDT
There is a bug in the analog output record that manifests
itself when you have specified a non-zero rate of change
(OROC) and are using hardware that maintains it's output
during a reboot (observed in Allen Bradley). This bug is
at least in 3.11.4 and all 3.12 Beta versions.
When these conditions occur, the output will be driven to
0, then ramp to the value that was readback from the hardware.
In the routine:
static long init_record(pao,pass)
    struct aoRecord     *pao;
    int pass;
    struct aodset *pdset;
    long        status=0;
    double      value;
    if (pass==0) return(0);
Need the end of the subroutine is:
        break;
    pao->pval = pao->val;
    return(0);
Which should be:
        break;
    pao->oval = pao->pval = pao->val;
    return(0);
Prev: Compability issues with VxWorks 5.2? mcgehee
Next: Real-Time Software Engineer Position Rick McGonegal
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
