1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Building for more than one host architecture
From: "Tony Carter, MIT Bates Linac" <[email protected]>
To: [email protected]
Cc: [email protected]
Date: Wed, 7 Jun 1995 14:38:35 -0400 (EDT)
Nick Rees writes:
>I thought the answer to your point was to move any host dependent
>definitions from CONFIG_SITE to CONFIG_SITE.Unix.<arch> (i.e the host
>dependent file already exists, and I wouldn't like creating a new
>one. It is also global so can be under the same CVS control).
>So, in your case, in CONFIG_SITE you would put:
>HOST_ARCH = $(shell HostArch)
>and possibly (but not necessarily - it could be omitted) a default of
>BUILD_ARCH = $(HOST_ARCH)
>However, in CONFIG_SITE.Unix.sun4 (or whatever), you would put:
>BUILD_ARCH = $(HOST_ARCH) mv167...
>or, more perversely, (i.e. I am not sure whether it will work), if you
>only wanted to build the IOC tools on this host architecture.
>BUILD_ARCH = mv167.
>This would override any definition in CONFIG_SITE, because
>CONFIG_SITE.Unix.<arch> is processed after CONFIG_SITE but before
>RULES_ARCHS, which is the only place it is used.
Yes, sorry for not paying closer attention to your original post.  I think
this works out well.  Thanks for everyone's input.
Tony
Prev: Re: Building for more than one host architecture Nick Rees
Next: Standard SMC driver/record support for R3.12? mcgehee
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Building for more than one host architecture Janet B. Anderson
