> Is anyone out there building EPICS on more than one host arch at the same
> time? Our development machine configuration is:
> Alpha/DEC Unix - Client applications
> Sun/SunOS - Client applications & IOC core/applications
> I want to have only one master copy of the EPICS development tree on an
> NFS server to be mounted by various development machines. Matt Needes
> and Mike Bordua (et al) did a nice job of laying things out so that
> object modules/executables/etc are kept seperate for different archs, so
> I don't see a problem there. But in ...config/CONFIG_SITE you must specify
> only one host architecture for HOST_ARCH. Swapping back and forth between
> machine specific CONFIG_SITE's is not an option.
> If there is no better solution, I can mount the base and extensions subdirs
> off of the server seperately and have arch specific config subdirs to be
> mounted as "config" on each development machine. It just seems like there
> should be a more intelligent solution. Is there?
I have one EPICS tree and use it to build Sun4, Solaris and SGI. I have gotten
around the problem you described (only 1 CONFIG_SITE file) in two different
ways:
- By typing "gmake install.sgi" when I want to build for SGI,
"gmake install.sun4" to build for sun4, etc. For most applications this
seems to work fine, i.e. the CONFIG_SITE file is then ignored. With this
method, simultaneous builds are possible.
- For those cases where this does not work I have 3 different CONFIG_SITE
files (CONFIG_SITE.my_sgi, etc.). I make a temporary soft-link from
CONFIG_SITE to these files. This obviously precludes truly simultaneous
builds.
____________________________________________________________
Mark Rivers (312) 702-2279 (office)
CARS (312) 702-9951 (secretary)
Univ. of Chicago (312) 702-5454 (FAX)
5640 S. Ellis Ave. (708) 922-0499 (home)
Chicago, IL 60637 [email protected] (Internet)
Task Delete of Sequence Crashes IOC Charles S . Higgins
PEP Modular Bitbus problems Claude Saunders
<1995>
Building for more than one host architecture Tony Carter, MIT Bates Linac
Re: Building for more than one host architecture William Lupton
<1995>
