Subject: |
Re: compress records |
[email protected] (Marty Kraimer) |
Date: |
Thu, 25 May 1995 11:08:15 -0500 |
> From denali!greene Thu May 25 09:29 CDT 1995
> From: <greene%[email protected]>
> Subject: compress records
> To: <[email protected]>
> Date: Thu, 25 May 1995 08:25:00 -0600 (MDT)
> X-Mailer: ELM [version 2.4 PL24]
> Mime-Version: 1.0
> Content-Transfer-Encoding: 7bit
> Content-Type> : > text/plain> ; > charset=US-ASCII>
> Content-Length: 596
> Looking at the documentation and the source for the compress records, it
> looks like the input to this record is a single sample of NSAM channels.
> I need to be able to average a waveform record buffer but it appears that
> the compress record cannot do this. Is this correct? If so, is there a
> record type already defined that will do this?
> Greg Greene
> KineticSystems Corp.
> ph: 303-220-7455 x13
> fax: 303-220-7458
The following is taken from the record reference manual (compress record)
If NTO1LOW, NTO1HIGH, or NTO1AVE are chosen, then VAL is a cdircular
buffer of length NSAM. ... If INP refers to an array, then each time the
record is processed, the array referenced by INP is obtained, divided into
sub_arrays each of length N and the algorithm applied to each sub-array.
The result from each subarray is written to the circular buffer referenced
by VAL.
If all you want to do is average a waveform just set
NSAM=1
ALG = NTO1AVE
N = length of input array
Marty Kraimer
compress records greene%denali.UUCP
VME bus confusion winans
<1995>
<1995>
