1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: compress records
Date: Thu, 25 May 1995 08:25:00 -0600 (MDT)
Looking at the documentation and the source for the compress records, it
looks like the input to this record is a single sample of NSAM channels.
I need to be able to average a waveform record buffer but it appears that
the compress record cannot do this.  Is this correct?  If so, is there a
record type already defined that will do this?
				Greg Greene
				KineticSystems Corp.
				ph:  303-220-7455 x13
				fax: 303-220-7458
Prev: Re: Postscript Documentation Marty Kraimer
Next: Re: compress records Marty Kraimer
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Postscript Documentation, Whoops! Tim Mooney
