1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: More than 1 output link
Date: Wed, 24 May 95 20:50:00 PDT
> >Does anyone know how to add more than 1 output link to a record?
> Unless the record supports it, you will have to use something like the sequence
> record.  It was designed to fetch values and then put them elsewhere (It has a
> group of link pairs in it.)  It was also designed to allow a delay between each
> transfer if you want... zero is an allowable delay.
> So then, you could point each of the inputs to the same place and all the outputs
> to... whereever and use a delay of zero, and get the effect you describe.
You might find the dfanout record more useful.  Point the single DOL at the incoming
value, then point the many OUT links as needed.  Be sure to set the mode to "closed
loop."
Steve
Prev: Re: Postscript Documentation, Whoops! Tim Mooney
Next: Re: Postscript Documentation Ian Smith
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: More than 1 output link winans
Next: Postscript Documentation Stefan Hippler
