1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: AO record DOL field fails with a CA link
Date: Wed, 3 May 1995 14:01:47 -0500
Epics Release 3.12.0Beta13 and earlier releases.
Setting the DOL field of an AO record to a channel access link fails.
The failure is the return of a completely nonsense value in the AO's VAL field.
There is no other indicia of failure.  We believe that the failure may occur
with DOL fields in other records such as BO.
The failure mechanism is understood and a fix is underway.
We have tickled a bug that has apparently been around for while.
Prev: pend_event 10ms min Chris Timossi
Next: Epics 3.12.0 Beta12 on Solaris Nick Rees
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: AO record DOL field fails with a CA link Bill Brown
