1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Device driver for NOAO instrument
Date: Tue, 18 Apr 1995 10:22:00 -0500
I would start by looking at the vxWorks/src/drv/serial/cd2400Serial.c file
that comes with the vxWorks distribution.  Just hack it up and you have a
vx(sometimes)Works serial driver that you can access by opening something
like /dev/myserial1 or what ever.  Look at the _vxWorks_ docs on drivers
(especially the tyCoDrv driver docs that outline the cd2400Serial.c file)
and the cd2400Serial.c file and you should have NO problems getting your
current paradigm ported.
Since it is all software and it won't actually wait to get the I/O finished (I
assume you are just pokeing around VME space and not waiting or spinning in the
driver?), I would write a regular (as in NOT async) device support that
write()'s your command string/data out the serial driver and does a blocking
read on its response (which will already be queued and ready.)
--John
Prev: Device driver for NOAO instrument Richard Wolff
Next: Re: Changing SCAN field dynamically Marty Kraimer
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: caWave and -lansi mcgehee
