1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: your mail
Date: Fri, 14 Apr 1995 18:04:14 EDT
> p.s.  One more question: is the record processing written in
> such a way that it only causes HSCN to write to the stringout
> when HSCN is written to directly (i.e. not every time the
> record gets processed?)
Thanks, first, for looking at this.
Ooops...Yep the HSCN writes to the stringout everytime the record
gets processed. But you see the magRec must trigger the stringout
or better said, only the magRec knows when it should changes its
scan period.
 I attempted to change the scan field internally in the record support
 but got errors.( I tried this first a looong time ago and don't remember
 the errors. Should I attempt it again to see what they were? )
 Sue
Prev: [none given] Bob Dalesio
Next: Changing SCAN field dynamically Marty Kraimer
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Release 3.12 415
