1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: DVX2502 addressing
Date: Tue, 28 Mar 1995 11:32:55 -0600
We have an application here at APS which utilizes up to 4 DVX2502
boards in one VME crate. While thumbing through the driver, I noticed
the register map structure pads out to 128 bytes, while the board base
addresses are selectable at 64 byte boundaries. Is there a particular
reason why the driver was set up this way? We can save some short IO
space by changing it.
Incidentally, I discovered that the sequence ram requires an extra
sample cycle at the end to reset the multiplexer properly (the driver
does this now, it just puzzled me when I saw it). Ie. if you scan 8
channels in a row, the sequence ram MUST be loaded to sample 9 times
before resetting to channel 0. Odd.
  - Claude Saunders
Prev: EPICS Arcnet Drivers. David Barker
Next: Re: dvx 2502 Jeff Hill
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
