Subject: |
Re: Reserved operand fault using CA on VMS |
[email protected] (Jeff Hill) |
Date: |
Sat, 11 Mar 95 10:59:50 MST |
Nick,
> OK, OK, all you users of CA on VMS ;-). Have you fixed this one before I
> embark on a fault finding exercise?
Maybe I should contact Intel and ask for a copy of their floating
point test :-}.
VAX D_FLOATING <=> IEEE double floating point conversion were recently
added to CA for EPICS release 3.12. I just looked at the code and it
does appear at first glance to be forcing the sign to zero when the
IEEE exponent is zero. I am forcing IEEE exponent values
outside the range of the VAX D_floating to have the proper value.
I also appear to be not allowing IEEE exponent values at the the
D_FLOATING range limit to convert into a zero D_FLOATING exponent
with a potentially negative sign.
Part of the problem here is that the VAC C compiler defaults to
D_FLOATING when G_FLOATING is a much better match for IEEE double
precision.
Nick, could you send the binary value of the IEEE value that
generated this exception? This can be obtained in the debugger
by examining the structure pointed to by pIEEE after the
exception occurs. You will need to compile CA for debugging.
I will look at the code in more detail on Monday.
Also is there a strong interest in retaining the 3.11 capability
for CA events to preempt the IPL0 thread via VMS ASTs for EPICS 3.12?
If so I will take another look at this on Monday also.
Jeff
______________________________________________________________________
Jeffrey O. Hill Internet [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos, NM 87545 USA FAX 505 665 5107
Reserved operand fault using CA on VMS Nick Rees
versioning ioc startup scripts for a control system Johnny Tang
<1995>
<1995>
