1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Reserved operand fault using CA on VMS
Date: Fri, 10 Mar 95 15:47:59 HST
OK, OK, all you users of CA on VMS ;-). Have you fixed this one before I
embark on a fault finding exercise?
Reserved operand fault at PC=0000AB55, PSL=03C00000
Symbolic stack dump follows
module name     routine name                     line       rel PC    abs PC
CONVERT         ntohd                           10008      00000005  0000AB55
CONVERT         cvrt_double                      8898      00000037  00009B0B
SERVICE         cacMsg                           8926      0000025B  0000B367
SERVICE         post_msg                         8730      000001B0  0000B0EC
IOCINF          ca_process_tcp                   9465      000000B8  00007D3C
IOCINF          ca_process_input_queue           9353      0000002D  00007AF9
VMS_DEPEN       cac_block_for_io_completion      9419      00000045  00006DB9
ACCESS          ca_pend                         11275      000001AD  00005EA5
THI_CA          thi_wait                         5192      00000012  00003E36
FAST_MAIN       FAST_MAIN                         153      00000075  00003875
The relevant bit of code (which has a comment about a similar problem) is:
 9996 /*
 9997  * sign must be forced to zero if the exponent is zero to prevent reserved
 9998  * operand fault- joh 9-13-90
 9999  */
10000 void ntohd(double *pNet, double *pHost)
10001 {
10002     double          copyin;
10003     struct mitdbl   *pMIT;
10004     struct ieeedbl  *pIEEE;
10005     ca_uint32_t     *ptmp;
10006     ca_uint32_t     tmp;
10007
10008     copyin = *pNet;
10009     pMIT = (struct mitdbl *)pHost;
10010     pIEEE = (struct ieeedbl *)&copyin;
10011
10012 /*
10013  * Byte swap from net order to host order
10014  */
10015     ptmp = (ca_uint32_t *) pIEEE;
Nick
Prev: mice mcgehee
Next: Re: Reserved operand fault using CA on VMS Jeff Hill
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: mice mcgehee
