1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: R3.12 Environment Parameter system
Date: Thu, 9 Mar 95 13:56:33 PST
I agree with Andrew Johnson that things could be neater.  As of Beta8,
near as I can make out definitions appear in 3 places (which are
slightly moved from Beta1) and where some over-rides occur--in some
cases in code, not headers-- (such as EPICS_IOC_LOG_PORT) in addition
to the intended overrides in resource.def and setenv.
Sorry for the width in the table below; right-most column over-rides.
Parameter		envDefs.h	epicsEnvParams.h	envSubr.c
EPICS_TS_MIN_VALUE			360
EPICS_IOC_LOG_VALUE			164.54.8.167
EPICS_IOC_FILE_VALUE			1000000
EPICS_IOC_LOG_FILE_TXT			/home/phebos.../iocLog.text
EPICS_TS_MIN_WEST						EPICS_TS_MIN_VALUE
EPICS_CMD_PROTO_PORT
EPICS_AR_PORT							7002
EPICS_IOC_LOG_PORT	6500					7004
EPICS_IOC_LOG_INET						EPICS_IOC_LOG_VALUE
EPICS_IOC_LOG_FILE_LIMIT 1000000				EPICS_IOC_FILE_VALUE
EPICS_IOC_LOG_FILE_NAME	./iocLog.text				EPICS_IOC_LOG_FILE_TXT
EPICS_CA_ADDR_LIST
EPICS_CA_CONN_TMO	30.0
EPICS_CA_BEACON_PERIOD	15.0
EPICS_CA_AUTO_ADDR_LIST	YES
EPICS_CA_REPEATER_PORT	5065
EPICS_CA_SERVER_PORT	5064
Found "epicsPrtEnvParams()" quite handy!  We have exercised the
EPICS_CA_ADDR_LIST to work across a routing Sun, and with
EPICS_CA_CONN_TMO and EPICS_CA_BEACON_PERIOD set very short I can
get snappy response!
I do thing a few changes in defaults would be more site-neutral:
EPICS_TS_MIN_VALUE		0		GMT
EPICS_IOC_LOG_VALUE		127.0.0.1	Loopback
EPICS_IOC_LOG_FILE_TXT		./iocLog.text	as booted
	Steve Lewis, Leader			[email protected]
	Computer Systems Group 			Mail Stop 46A-1123
	Lawrence Berkeley Laboratory		Tel: 510/486-7702
	Berkeley, CA 94720			Fax: 510/486-5936
Prev: Re: Array Records Johnny Tang
Next: Epics Port to Linux jpq
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: R3.12 Environment Parameter system Marty Kraimer
Next: Re: R3.12 Environment Parameter system Andrew Johnson
