1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: How to use CVS to backup soft links ?
Date: Tue, 28 Feb 95 07:51:00 PST
On Gammasphere we solved the soft link backup problem by writing a simple
couple of scripts for making and deleting links.  These scripts use a textfile
that describes the links that can easily be edited.  One builds links, another
deletes them, and a third lists them in the format for the file.  The
makefiles then contain a target 'links' so you can, after a cvs checkout, say
'make links' and it makes all the links for the tree.  It is not recursive,
but the links description file can describe links deeper in the tree.
Thus you can do it all from one file or have local files per directory
or subtree.
Many variations on this theme are possible and easy.  Moving the link
declarations into text proved a simple way to clean them up, as well.
Once they are all in one textfile it is easy to see how to make them
more organized (like using the release link in all relovent link paths).
We're quite happy with this solution and will use it again.  If folks
are interested we can post the scripts - they are pretty short.
Alan K Biocca
>   How to backup soft links with CVS ? One of suggestions is
> to tar the links and cvs that tar file. Is there any other
> way you may suggest ?
>   Thanks,
>   ---- Johnny Tang
Prev: Re: How to use CVS to backup soft links ? Matthew Needes
Next: Security Toolkit Ian Foster
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
