Subject: |
bug in recCompress.c |
"F. Gougnaud" <[email protected]> |
Date: |
Mon, 13 Feb 95 14:39:42 GMT |
I have corrected a bug in the recCompress.c file in EPICS release 3.11.
The AVERAGE algorithm doesn't work when the N field is greater than 1 (!)
because the routine array_average() doesn't update the INX record's field.
The routine must be modified like this:
/* do we need to calculate the result */
inx++;
if (pcompress->n<=0) pcompress->n=1;
n = pcompress->n;
pcompress->inx = inx; <---- add this line
if (inx<n) return(1);
if (n>1) {
pcompress->inx = 0; <---- and this line
psum = (double *)pcompress->sptr;
multiplier = 1.0/((double)n);
for (i = 0; i < nuse; i++, psum++)
*psum = *psum * multiplier;
put_value(pcompress,pcompress->sptr,nuse);
return(0);
A suggestion for the compress record type:
in 3.11 it's not possible to modify the N field of a compress record from
an application. For that, the N field definition in the compressRecord.ascii
file need to be changed like this:
(before) "N to 1 Compression" N SPC_NOMOD DBF_ULONG ...
(after) "N to 1 Compression" N SPC_RESET DBF_ULONG ...
Yves Lussignol.
Re: Making releases Noboru Yamamoto
Re: bug in recCompress.c Rozelle Wright
<1995>
Re: Making releases Alan K Biocca
<1995>
