1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: string to binary conversion in the db
Date: Fri, 10 Feb 1995 09:13:39 -0600
The following changes seem safe (I agree with John that aliasing, etc.
is too dangerous). I also agree that someting should be done because
this request has been expressed previously.
For all the choice types (DBF_ENUM, DBF_GBLCHOICE, DBF_CVTCHOICE,
DBF_RECCHOICE, DBF_RECCHOICE) do the following for DBR_STRING.
1) Compare the string with each string choice just like existing code.
   If success then this is just like existing code.
2) If 1) fails then do the following:
   perform an sscanf on the string to convert to unsigned int.
   If the following are true then change the field:
       a) The number of characters consumed = strlen(input string)
       b) The index value is < number of choices for the field.
   If either a or b is false then fail just like existing code.
Marty Kraimer
Prev: Re: string to binary conversion in the db John R. Winans
Next: Re: EPICS on the Alpha 415
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Observations on EPICS Alpha port & DEC support of VxWorks 415
