1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS on the Alpha
Date: Fri, 10 Feb 1995 08:13:16 -0600
I agree with your logic flow 100% WRT internal data structure sizes and
implied sizes and so on.  However, I would rather see the IOC data structures
completely rethought.  Let them become what ever the native machine wants,
clean up the int <-> void* assignments, and simply do all transfers of the
database in ASCII.  This would allow all the iocCore code to compile into
what ever byte size and sex it wants... who cares?  Lose the 'for the
sake of speed' code that is not portable... or at least provide ifdef'd
alternates so that EPICS can be made portable.
That would leave the CA code... it has to be fixed anyway.
There is, however, going to be some trouble with the drivers.  I am not sure
that they can be made as portable.  They will ALWAYS require an exact byte sex
and size when they are defining their register maps.  I suppose your typedef
idea would be a good start at it.  But there is always going to be timing
and BSP-dependancies that some of them will not be able to overcome.
--John
Prev: AT-9 transition module Ian Smith
Next: Re: string to binary conversion in the db John R. Winans
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: EPICS on the Alpha 415
