g+
g+ Communities
Argonne National Laboratory
1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Subject: Re: IOC time 1min=90sec ??
Date: Mon, 16 Jan 1995 10:56:45 -0600
On your ioc
1) Find out what sysClkRateGet returns
2) Call tickGet twice and manually measure the time between calls
Does (tickget2 - tickget1)/sysClkRateGet equal the time you measured?
> From csuka@heracc.desy.de Mon Jan 16 10:44 CST 1995
> Date: Mon, 16 Jan 1995 17:46:28 EST
> From: "Gabor Csuka, DESY - Germany" <csuka@heracc.desy.de>
> To: tech-talk@aps.anl.gov
> Cc: csuka@heracc.desy.de
> Subject: IOC time 1min=90sec ??
> Content-Type> : > text>
> Content-Length: 841
> Hi,
> Our IOC -s time is after a correct syncronization working too fast.
> After 40min the time is increasd with 1 hour. Where is my failure ?
> Our configuration:
> NO hardware clock, NO NTP server
> 1 ioc:
> TSconfigure (1, 10, 60, 0, 0)
> -> TSreport
> Soft timing slave
> Master timing IOC alive
> Time protocol sync with unix
> Clock Rate in Hertz = 60
> Sync Rate in Seconds = 10
> Master communications port = 18323
> Slave communications port = 18322
> Total events supported = 1
> Request Time Out = 250 milliseconds
> The others:
> TSconfigure (0, 10, 60, 0, 0)
> -> TSreport
> Soft timing master
> Any idea ???
> Gabor Csuka
> DESY
Prev: Re: TS - EAST from GMT Marty Kraimer
Next: TS - EAST from GMT Gabor Csuka, DESY - Germany
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Prev: Re: TS - EAST from GMT Andrew Johnson
Next: Re: IOC time 1min=90sec ?? winans
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
