g+
g+ Communities
Argonne National Laboratory
1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Subject: Bug in DM using long records?
Date: Thu, 5 Jan 1995 21:21:12 GMT
Can anyone confirm the following behaviour of DM?  I think it is be a bug, and a
fairly old one at that:
I have a longin record, Soft record type, running in an IOC running 3.12Beta1,
but I suspect the IOC release is irrelevant.
I have a display created using EDD (3.12Beta1), with a Valuator and an Indicator
both connected to the above longin record.
When I run up the display under DM, the limits on both the Valuator and
Indicator are not the same as the High and Low Operating range of the record.
If I move the valuator, the Indicator does not move, although it is obviously
being refreshed.  However I can use cau to monitor the record and it shows it
changing correctly to the Valuator settings. If I ask the DM window to refresh,
the Valuator jumps to a seeming random value, although cau does not show the
record changing.
I have checked this using DM from 3.11.4, and a similar behaviour occurs.
- Andrew
          ,_}\_.        Andrew Johnson, Technology Division
         /      \       Royal Greenwich Observatory
~~~~~~~~| ,--/;. )~~~~  Madingley Road, Cambridge, UK
    .,  |/  (/  U       Phone: +44 (0)1223 374823
  .`., /_\ . .          Email: anj@mail.ast.cam.ac.uk
     wwWWWww'           WWW: http://cast0.ast.cam.ac.uk/~anj/
Prev: Re: Epics release 3.12.Beta3 - apology watson
Next: Re: Bug in DM using long records? Carl Timmer
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Prev: RE: Epics release 3.12.Beta3 - apology Gabor Csuka, DESY - Germany
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
